Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 13 Online Documentation
JMP 12 Online Documentation
Essential Graphing
Scatterplot 3D
The Scatterplot 3D Report
• Adjust the Axes
Adjust the Axes
You can manually move or rescale the axis coordinates by clicking and dragging the axis. This option shows a different set of coordinates on the 3D scatterplot. It also lets you change the space displayed between the coordinates (or the coordinate scaling).
You can also specify axis properties by double-clicking the axis and modifying settings in the specifications window.
To Move the Coordinates on the Axis
Place your cursor over the middle of the axis.
Click and drag the axis.
To Modify Coordinate Scaling
Place your cursor over the end of the axis.
To Rescale an Axis Precisely
Place your cursor over the middle of the axis (the axis, not the label).
Double-click the axis.
Change the minimum and maximum coordinate values.
For more details about updating axes, see
Customize Axes and Axis Labels in the Axis Settings Window
and
Customize Axes and Axis Labels Using the Pop-Up Menu
in the
Using JMP
book.
Help created on 7/12/2018
