Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 13 Online Documentation
JMP 12 Online Documentation
Scripting Guide
Data Tables
• Basic Data Table Scripting
Before you can work with data table objects, you must open or create a data table, and assign a reference to the data table.
Open a Data Table
Create a New Data Table
Import Data
Set the Current Data Table
Name a Data Table
Save a Data Table
Hide a Data Table
Print a Data Table
Resize a Data Table
Select Columns in a Data Table
Set and Get a Data Table
Perform Actions on All Open Data Tables
Create Journals
Create Excel Workbooks
Prevent Changes to a Data Table
Help created on 7/12/2018
