dt1 = Open( "$SAMPLE_DATA/Big Class.jmp" );
dt2 = New Table( "Cities" );
To switch to another open data table, specify the name of the data table in Current Data Table():
Current Data Table( dt1 ); // makes Big Class.jmp the current data table
Current Data Table() can also take a scriptable object reference as an argument. The following expression would make the data table in use by the second Bivariate object the current data table:
Current Data Table( Bivariate[2] );
