This example uses Capacitor ALT.jmp and can be found in the Reliability folder of the sample data. It contains simulated data that gives censored observations for three levels of temperature, for a reliability study. Observations are shown as censored values at temperature levels of 85, 105, and 125 degrees Celsius.
Leave the Censor Code as 1.
7.
8.
9.
Select Weibull as the distribution.
10.
Keep Wald as the confidence interval method.
Figure 3.22 shows the completed launch window.
Figure 3.22 Fit Life by X Launch Window
11.
Click OK.
Figure 3.23 shows the top half of the Fit Life by X report window.
