Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 13 Online Documentation
JMP 12 Online Documentation
• Fit Life by X
Fit Life by X
Fit Single-Factor Models to Time-to Event Data
The Fit Life by X platform helps you analyze lifetime events when only one factor is present. You can choose to model the relationship between the event and the factor using various transformations, or create a custom transformation of your data. You also have the flexibility of comparing different distributions at the same factor level and comparing the same distribution across different factor levels.
Figure 3.1
Scatterplot Showing Varying Distributions and Factor Levels
Contents
Overview of the Fit Life by X Platform
Example of the Fit Life by X Platform
Launch the Fit Life by X Platform
The Fit Life by X Report
Summary of Data
Scatterplot
Nonparametric Overlay
Comparisons
Results
Custom Relationship
Fit Life by X Platform Options
Additional Examples of the Fit Life by X Platform
Capacitor Example
Custom Relationship Example
Help created on 7/12/2018
