Saves columns called Cluster <i> Components to the data table. Each column contains a formula that expresses the cluster component in terms of the uncentered and unscaled variables.
Tip: To fit a model using the components, first select the Save Cluster Components option. Then replace the Most Representative variables for each cluster in the Construct Model Effects list with the desired Cluster Components columns.
See Local Data Filter, Redo Menus, and Save Script Menus in the Using JMP book for more information about the following options:
