Shows the t-value or other corresponding quantiles used for confidence intervals.
Shows a matrix showing if a difference exceeds the least significant difference for all comparisons.
(Available only for Each Pair, Student’s t.) Shows a detailed report for each comparison. Each section shows the difference between the levels, standard error and confidence intervals, t-ratios, p-values, and degrees of freedom. A plot illustrating the comparison appears on the right of each report.
