The Each Pair Stepwise, Newman-Keuls test compares the sample means using an iterative, stepwise procedure. For an example of this test, see Example of the Each Pair Stepwise, Newman-Keuls Test. The procedure JMP uses for testing J group means is described as follows:
If there is no significant difference, set the p-values of any subranges of the two means to 1. Continue the testing procedure for ranges that are not contained within the two means. If there are no such ranges, stop the procedure.
After the first non-significant test, the remaining p-values are set equal to 1. After a significant test, the level that is not included in the subsequent Tukey’s HSD test retains the p-value of the previous test. This is the p-value that is reported for that level in the Ordered Differences Report.
Note: There are no mean circles added to the Comparison Circles graph when you use the Each Pair Stepwise, Newman-Keuls test. This is because each comparison has a different cut-off depending on the number of means between the two means being tested. Therefore, each circle would be a different size.
