To begin, select File > SAS > Server Connections. The SAS Server Connections window shown in Figure 2.14 appears. All connections are made in this window.
Figure 2.14 SAS Server Connections
Select File > SAS > Server Connections. The SAS Server Connections window shown in Figure 2.14 appears.
Click Connect.
If JMP is unable to establish a connection, an error message appears. Common reasons are invalid user names or passwords. If you need to update the information for the profile, see To create or modify a SAS Metadata Server profile.
Click Close.
Figure 2.15 Open a Connection to a Workspace Server
Click Connect.
Under Open Workspace Server Connections, the Workspace Server is shown as the current active connection. See Figure 2.16.
Figure 2.16 Current Active Connection
Click Close.
To change the active connection, you first need to be connected to more than one server. Follow the instructions in To connect to a SAS Workspace Server (Windows only) to add two or more server connections.
Click Set as Active.
Click Close.
Click Disconnect.
Click Disconnect.
In the SAS Server Connections window, select the SAS Server Version.
Click Manage Profiles.
Figure 2.17 Create or Modify a Metadata Server Profile
The name of the machine that hosts the Metadata Server. (Example: myserver.mycompany.com)
Click Save.
You can also connect directly to a SAS Workspace Server, instead of going through a Metadata Server.
Under Establish New Workspace Server Connection, select Connect to remote SAS server on. See Figure 2.18.
Figure 2.18 Open a Connection to a Remote SAS Server
Click Connect.
6.
Click OK.
7.
Click Close in the SAS Server Connections window.
Click Disconnect.
On Windows, you can connect to a SAS mid-tier (or SAS environment) if SAS Server version 9.3 or 9.4 is selected in JMP’s preferences and your computer or JMP has been configured correctly. (SAS Server version 9.4 is the default setting in the JMP SAS Integration preferences.)
Select File > Preferences > SAS Integration.
To connect to an environment that JMP has already detected, click Automatic discovery, and then select the URL from the list if necessary.
To enter the path to the SAS environment definition file, click Manual configuration and enter the URL.
Click OK.
Select File > SAS > Server Connections to open the SAS Server Connections window.
In the Metadata Server Connection area, select Connect to a SAS Environment.
If this option is not available, either your computer or JMP is not configured to find the environment. See To configure your JMP preferences for details.
Click Connect.
Under Establish New Connection, select Connect to SAS on this machine.
Click Connect.
In the SAS Server Connections window, select Local under Open Connections.
Click Disconnect.
