Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 13 Online Documentation
JMP 12 Online Documentation
Using JMP • Import Your Data
Import Your Data
Create Data Tables
This chapter covers the following topics:
How to import data into JMP, such as text files, SPSS files, and SAS data
How to transfer Excel data into a JMP data table
How to read in real-time data
How to create a new data table
Figure 2.1
Importing a Text File
Contents
About Importing Data to JMP
Import Microsoft Excel Files
Preview and Import the Microsoft Excel Data
Import a Microsoft Excel File Directly
Import Data from SAS
Java Runtime Environment (JRE) Requirements
SAS Menu Options
Import SAS Data Sets
Create SAS Transport Files in SAS
Connect to SAS
Open SAS Data Sets with SAS Query Builder
Open SAS Data Sets through a SAS Server
Using SAS Extended Attributes to Import Metadata
Run Stored Processes
Submit SAS Code
Generate ODS Results
Retrieve Generated SAS Data Sets
Build SQL Queries in Query Builder
Connect to a SQL Database
Select Tables from a SQL Database
Build the SQL Query
Save and Run the Query
Open the Selected Data in JMP
Query Builder Red Triangle Options
Write SQL Statements in Query Builder
Import Data from a Database
Connect to a Database
Open Data from a Database
Write SQL Statements to Query a Database
Structured Query Language (SQL): A Reference
Import Text Files
Text Import Wizard Options
Open a Text File in a Text Editing Window
Import Text from the Script Editor
Import Multiple Files
Import Data from the Internet or a Remote Computer
Import SPSS Files
Import Triple-S Survey Data
Import HDF5 Data
Import JSON Files
Import Data from MATLAB
Import Data from R
Import Data Using the Excel Add-In
Transfer Excel Data to a JMP Data Table
About the JMP Add-In for Excel
Uninstall the Excel Add-In
Create New Data Tables
Help created on 7/12/2018
