Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 13 Online Documentation
JMP 12 Online Documentation
Profilers
Mixture Profiler
Mixture Profiler Platform Options
• Customizations for the Mixture Profiler
Customize the Mixture Profiler by right-clicking on the plot, and selecting
Customize
Contour
Alter line color, fill color, and level of line transparency. If there are multiple contour lines on the plot, each appears individually on the list of options.
Component Constraints
Alter component constraint display properties.
Linear Constraints
Alter linear constraint display properties.
Grid Lines
Use Axis Settings window to modify grid lines.
Reference Lines
Use Axis Settings window to modify reference lines.
Double-click an axis on the plot to view the Axis Settings window. Here you can specify axis properties in detail, such as tick marks, grid lines and reference lines.
Crosshairs
Alter the display properties of the crosshairs on the plot.
Marker
Alter the display properties of the plot marker.
Help created on 7/12/2018
