Opens a dialog for specifying factor values. The entered values should sum to1. If needed, JMP adjusts the specified values to feasible settings. The option is also available from the Change button on the report window.
Shows or hides the three-way crosshairs on the plot. The intersection of the crosshairs represents the current factor values. The Current X values above the plot give the exact coordinates of the crosshairs.
Shows or hides the shading resulting from any constraints on the factors. Those constraints can be entered in the Lo Limits and Hi Limits columns above the plot, or in the Mixture Column Property for the factors.
