Saves the histograms as .swf files that are Adobe Flash player compatible. Use these files in presentations and in web pages. This option also saves an HTML page that shows you the correct code for using the resulting .swf file.
For more information about this option, go to https://jmp.com/support/swfhelp/en.
See Local Data Filter, Redo Menus, and Save Script Menus in the Using JMP book for more information about the following options:
Help created on 7/12/2018
