Reorders the histogram, mosaic plot, and Frequencies report in ascending or descending order, by count. To save the new order as a column property, use the Save > Value Ordering option.
Displays a report that tests hypothesized probabilities. See Examples of the Test Probabilities Option for more details.
This menu contains confidence levels. Select a value that is listed, or select Other to enter your own. JMP computes score confidence intervals.
