Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 13 Online Documentation
JMP 12 Online Documentation
Process Capability
• Entering Specification Limits
The lower specification limit (LSL), upper specification limit (USL), and target define the lower bound, upper bound, and target value for a quality process.
There are several ways to enter specification limits:
Enter limits in the Spec Limits window after selecting columns in the launch window. See
Spec Limits Window
Import limits from a JMP data table (known as a Limits Table). See
Limits Data Table
Enter limits as Spec Limits column properties in the data table. See
Spec Limits Column Property
If you are creating a Process Capability report by running a JSL script, enter limits in the script. See
The Process Capability Report
Only one specification limit is required for a selected column. If only the USL is specified, the box plots and Goal Plot point are colored blue. If only the LSL is specified, the box plots and Goal Plot point are colored red.
Help created on 7/12/2018
