Note: It is good practice to ensure that specification limits for all process variables are specified as Spec Limits column properties or to load specification limits from a Limits Data table (see Limits Data Table). Otherwise, you can specify limits interactively in the Spec Limits window that appears after you click OK in the launch window (unless you select No (skip columns with no spec limits) on the launch window).
