This example uses the Hot Dogs.jmp sample data table. Examine the relationship between hot dog type and taste.
Select Help > Sample Data Library and open Hot Dogs.jmp.
Select Analyze > Fit Y by X.
Select Type and click Y, Response.
Select Taste and click X, Factor.
Select Protein/Fat as the grouping variable and click OK.
Figure 6.107 Example of a Cochran-Mantel-Haenszel Test
From Figure 6.107, you notice the following:
Help created on 7/12/2018
