Select Analyze > Screening > Association Analysis.
Click OK.
By default, the Rules report is sorted in decreasing order by Confidence. However, association rules with extremely high confidence also tend to have a higher number of items in the condition set. Since you want to view association rules with smaller condition sets, sort the report by Confidence, but in increasing order.
6.
Right-click in the Rules report and select Sort By Column.
7.
Select Confidence and the check the ascending order option.
8.
Click OK.
Figure 20.2 Association Analysis Report
9.
Scroll down the report to where the Confidence values are 58%.
Figure 20.3 Frequent Item Sets Report
The Frequent Item Sets report shows that 36% of customers purchased avocados. The Rules report in Figure 20.2 shows that 58% of these customers also bought artichokes. Because of the large proportion of customers who follow this behavior, the grocery store management might use this information to strategically locate avocados and artichokes.
11.
Right-click in the Rules report table and select Sort By Column.
12.
13.
Right-click in the Frequent Item Sets report and select Sort By Column.
14.
Select Item Set and the check the ascending order option.
15.
Click OK.
