This example uses the Devalt.jmp sample data table, from Meeker and Escobar (1998), and can be found in the Reliability folder of the sample data. It contains time-to-failure data for a device at accelerated operating temperatures. No time-to-failure observation is recorded for the normal operating temperature of 10 degrees Celsius; all other observations are shown as time-to-failure or censored values at accelerated temperature levels of 40, 60, and 80 degrees Celsius.
Select Analyze > Reliability and Survival > Fit Life by X.
Leave the Censor Code as 1.
7.
8.
9.
Select Weibull as the distribution.
10.
Keep Wald as the confidence interval method.
Figure 3.2 shows the completed launch window.
Figure 3.2 Fit Life by X Launch Window
11.
Click OK.
Figure 3.3 shows the top half of the Fit Life by X report window.
