Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 13 Online Documentation
JMP 12 Online Documentation
Evaluate Designs
Evaluate Design Window
• Factors
Factors
The factors outline lists the factors entered in the launch window. You can select factors to construct effects in the Model outline.
Figure 14.12
Factors Outline
Help created on 7/12/2018
