Note: The Fit Group menu appears if you have specified multiple Y or multiple X variables. Menu options allow you to arrange reports or order them by RSquare. See Fit Group Options in the Fitting Linear Models book for more information.
Attaches histograms to the x- and y-axes of the scatterplot. A check mark indicates that histogram borders are turned on. See Histogram Borders.
Note: When you apply only the Hidden row state to rows in the data table, the corresponding points do not appear in the scatterplot. However, the histograms are constructed using the hidden rows. If you want to exclude rows from the construction of the histograms and from analysis results, apply the Exclude row state and select Redo > Redo Analysis from the Bivariate red triangle menu.
Lets you select a classification (or grouping) variable. A separate analysis is computed for each level of the grouping variable, and regression curves or ellipses are overlaid on the scatterplot. See Group By.
See Local Data Filter, Redo Menus, and Save Script Menus in the Using JMP book for more information about the following options:
