Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 13 Online Documentation
JMP 12 Online Documentation
Association Analysis
The Association Analysis Report
• Frequent Item Sets
Frequent Item Sets
The Frequent Item Sets report lists item sets in decreasing order of support. The listed item sets meet the Minimum Support value that you specified in the launch window. Each item set is considered as a conditional and as a consequent item set to form association rules. The table contains the following columns:
Item Set
The item sets that are considered as conditional or consequent sets for the association rules.
Support
The proportion of transactions in which all of the items in the Item Set occur.
N Items
The number of items in the Item Set.
Help created on 7/12/2018
