JMP uses the import settings in the preferences to determine how to structure and format the text. Some options include removing quotation marks around text and specifying the rows that contain column headings and data. See Text Data Files in JMP Preferences for details.
Note: You can also import an entire web page as a data table. See Import Data from the Internet or a Remote Computer for details.
This section describes how to import text that you paste into the Script Editor. For details about opening a text file in the Script Editor, see Open a Text File in a Text Editing Window.
Open a new Script window in JMP by selecting File > New > Script (Windows) or File > New > New Script (Macintosh).
To import all text from the Script Editor, select File > Import as Data (Windows) or Edit > Import as Data (Macintosh).
To import specific text, select the text, and then select File > Import as Data (Windows) or Edit > Import as Data (Macintosh).
