Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 13 Online Documentation
JMP 12 Online Documentation
Discovering JMP
Special Features
• Integrate JMP and SAS
Note:
You must have access to SAS, either on your local machine or on a server, to use SAS through JMP.
Using JMP, you can interact with SAS as follows:
Write or create SAS code in JMP.
Submit SAS code and view the results in JMP.
Connect to a SAS Metadata Server or a SAS Server on a remote machine.
Connect to SAS on your local machine.
Open and browse SAS data sets.
Retrieve and view data sets generated by SAS.
For complete details about integrating JMP and SAS, see
Import Data from SAS
in the
Using JMP
Help created on 7/12/2018
