Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 13 Online Documentation
JMP 12 Online Documentation
Profilers
• Introduction to Profilers
Visualize Response Surfaces and Optimize Processes
Profiling is an approach to visualizing response surfaces by seeing what would happen if you change just one or two factors at a time. Essentially, a profile is a cross-section view. The interactive profilers in JMP promote exploring opportunity spaces. In fitting equations to data, the fitting is only the first step. Interpreting the fit, understanding the fitted response surface, and finding factor values to optimize the responses is desirable.
Figure 1.1
Examples of Profilers
Contents
Overview of the Profiler Platform
Introduction to Profiling
Profiler Features in JMP
Profiler Launch Windows
Fit Group
Interpret the Profiles
Profiler Platform Options
Common Profiler Topics
Linear Constraints
Noise Factors
Help created on 7/12/2018
