Creates code for the OPTMODEL SAS procedure. Hold down CTRL and SHIFT and then select Formulas for OPTMODEL from the red triangle menu.
The following options are available in many platforms. See Local Data Filter, Redo Menus, and Save Script Menus in the Using JMP book for more information.
