Helps determine whether the curves are similar in shape when they are shifted along the X axis. In certain situations, it is important to establish parallelism before making further comparisons between groups. This option is available only when a Group variable is specified on the platform launch window. This option is available for the Sigmoid models (Logistic and Gompertz), as well as the Linear Regression model, with the exception of higher-order polynomials. For details, see Test Parallelism.
Gives an analysis for testing the equality of parameters across levels of the grouping variable. This option is available only when a Group variable is specified on the platform launch window. For details, see Compare Parameter Estimates.
Gives an analysis for testing the equivalence of models across levels of the grouping variable. This option is available only when a Group variable is specified on the platform launch window. For details, see Equivalence Test.
Shows or hides a profiler of the fitted prediction function. The derivatives are derivatives of the prediction function with respect to the X variable. For more information about profilers, see Profiler in the Profilers book.
Predicts an X value for a specific Y value. For more information about inverse prediction, see Inverse Prediction in the Fitting Linear Models book.
