Gives the estimates of the parameters, standard errors, Chi-squared statistics, p-values, and confidence intervals. The correlations and covariances of the estimates are given also.
Tip: You can sort the Parameter Estimates report table by clicking on the column you wish to sort by.
Gives plots of the data with the fitted model. See Figure 11.7. The plots are shown only when you select a Grouping variable on the platform launch window.
