Optimal mixture designs use the Custom Design platform with the mixture variables entered into the response and factors panels.
Select DOE > Classical > Mixture Design.
Click Continue.
Click Optimal on the Choose Mixture Design Type panel.
6.
8.
10.
11.
Click Make Design.
Figure 12.6 12-Run Optimal Design Runs
12.
Click Make Table.
From the design table, select Graph >Ternary Plot.
Figure 12.7 Ternary Plot for Optimal Design
