A simplex centroid design of degree k with n factors consists of mixtures with the following characteristics:
additional blends, up to k factors at a time blended at k equal levels
Select DOE > Classical > Mixture Design.
Click Continue.
Click Simplex Centroid to generate the design
Note: The default setting of k = 2 was used. There is a text box that enables you to adjust the value of k.
Figure 12.8 Three Factor Simplex Centroid Design of Degree 2.
Click Make Table.
6.
From design table, select Graph>Ternary Plot.
7.
Select X1, X2, and X3 and click X, Plotting, and then click OK.
Figure 12.9 Ternary Plot for Simplex Centroid Design
Help created on 7/12/2018
