Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 13 Online Documentation
JMP 12 Online Documentation
Compare Designs
• Overview of the Compare Design Platform
The Compare Designs platform, which is an extension of the Evaluate Design platform, enables you to easily compare two or three designs. To compare the performance of one or two designs relative to another, you select a reference design that is treated as the base design. You can specify effects in the Model outline, and effects of interest in the Alias Terms outline.
The Design Evaluation report shows diagnostic results and plots covering these areas:
Power analysis
Prediction variance
Fraction of design space
Relative estimation efficiency
Alias matrix diagnostics
Correlations among effects (including confounding)
Relative efficiency measures for the overall designs
Help created on 7/12/2018
