Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 13 Online Documentation
JMP 12 Online Documentation
Compare Designs
Compare Designs Window: Specify Model and Alias Terms
• Reference Design
Reference Design
The name of the window for the reference design appears in the outline title. The Matching Specification outline lists the specifications that you entered in the launch window.
Factors
Use the Factors outline to add effects to the Model and Alias Terms lists.
The Factors outline lists the factors, using the column names from the reference design, and coded values. Because they are not factors, whole plot and subplot columns do not appear in the Factors outline. However, they are required for the analysis.
Help created on 7/12/2018
