Optional, Boolean. If True, the main result filename is returned as a full path. The default value is False.
Optional, Boolean. If True, the filename returned for each result file is returned as a full path; if False, only the name of the file is returned. The default value is False.
Quoted string that contains the name of the file from the generated results to open. filename should just be the name of the file, not the full path. If filename is a filename with no extension, both JMP data tables and JSL scripts in the results are searched for a match, and if both exist, both are opened.
Optional, Boolean. If True, and if filename is a JSL script, the script is executed. If False, filename is just opened, even if it is JSL.
Quoted string that contains the name of the JSL file from the generated results to open. Filename should just be the name of the file, not the full path, and it does not need to include the .jsl extension.
