To add specification limits to a variable, right-click the desired column and select Column Properties > Spec Limits. In the Column Properties window, there are boxes to enter values for the Lower Spec Limit, Target, and Upper Spec Limit. Alternatively, you can define Specification Limits using the Spec Limits option in the Simulator red triangle menu.
