Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 13 Online Documentation
JMP 12 Online Documentation
Basic Analysis
Oneway Analysis
Means/Anova and Means/Anova/Pooled t
• The Block Means Report
If you have specified a Block variable on the launch window, the
Means/Anova
and
commands produce a Block Means report. This report shows the means for each block and the number of observations in each block.
Help created on 7/12/2018
