The Means/Anova option performs an analysis of variance. If the X factor contains exactly two levels, this option appears as Means/Anova/Pooled t. In addition to the other reports, a Pooled t-test report assuming pooled (or equal) variances appears.
See The Summary of Fit Report, The Analysis of Variance Report, The Means for Oneway Anova Report, The t-test Report, and The Block Means Report.
The t-test report appears only if the Means/Anova/Pooled t option is selected.
