Shows an interactive report that enables you to add or remove effects from the model. See Effect Summary Report in the Fitting Linear Models book.
(Available only for the Weibull distribution.) Shows the parameter estimates for the α and β parameterization of the Weibull distribution. For more information about this parameterization, see Weibull in Life Distribution.
Figure 13.5 The Parametric Survival Fit Report
