In your Excel worksheet, show the JMP add-in on the ribbon.
Click the Preferences button.
Accept the default Data Table Name (File name_Worksheet name) or type a name.
Select Use the first rows as column names if the first row in the worksheet contains column headers.
6.
Select Transfer Hidden Rows if the worksheet contains hidden rows to be included in the JMP data table.
7.
Select Transfer Hidden Columns if the worksheet contains hidden columns to be included in the JMP data table.
8.
Click OK to save your preferences.
