This example uses the Failures.jmp sample data table, which contains failure data and a frequency column. It lists causes of failure during the fabrication of integrated circuits and the number of times each type of defect occurred for two processes. A constant sample size of 1000 is specified for this example.
7.
8.
Click OK.
Figure 11.10 Pareto Plot Report Window
9.
Figure 11.11 Test Rates across Groups Results
