In a JMP project, you can open data tables and then run analyses on the data. Each data table and analysis report opens in a new tab.
1. From a project window, select File > Open and navigate to the data tables that you want to open.
2. From a data table, run an analysis.
If a data table is updated on your computer, any associated reports in your project update when you reopen the project.
Figure 10.14 Initial ProjectÂ
Tip: You can use JMP keyboard shortcuts in projects, such as Ctrl+S to save a file, or Ctrl+W to close the active window pane. For a full list, select Help > Quick Reference Card.
