Using JMP > Save and Share Your Data > Work with Projects
Publication date: 09/28/2021
Work with Projects
With JMP projects, you can do the following:
Explore your data more efficiently with a single, tabbed JMP window
Quickly save and reopen a set of related files and reports
Easily share your work by embedding your tables and scripts in a self-contained project file
Figure 10.13 Project File with Data Tables and Reports
This section contains the following information:
Create a New Project
Open Files in a Project
Rearrange Files in Projects
Save a Project
Project Workspace
Project Bookmarks
Project Contents
Recent Files in Projects
Project Log
Move Files into Projects
Write a Project On Open Script
Example of Creating a New Project
