Select File > Export or File > Save As to save a data table in another format such as Microsoft Excel or CSV.
Note: To save a data table as a journal, select Edit > Journal and then File > Save As.
JMP saves data tables in the formats listed in Table 10.1.
File Type(s) |
OS Availability |
JMP Data Table (.jmp) |
All |
Excel Workbook (.xls, .xlsx) |
All |
Text Export File (.txt) |
All |
Comma-delimited File (.csv) |
Windows |
Tab-delimited File (.tsv) |
Windows |
SAS Data Set (.sas7bdat) |
All |
SAS Data Set with Extended Attributes (.sas7bxat) Note: JMP can save column properties and table properties as extended attributes in a SAS 9.4 .sas7bxat file. Select File > Export, select the SAS file type, and then select the check box for saving extended attributes. JMP names the file with the .sas7bxat extension. The SAS Integration preferences also include this option, which is off by default. |
Windows |
SAS Transport File (.xpt,.stx) |
All |
JSON Data File (.json) |
All |
You can also save files for types that have a corresponding ODBC driver. See Save Data Tables to a Database.
Notes:
• The maximum length of the data table’s name depends on your computer’s operating system. See your operation system documentation for details.
• JMP tries to save any modified files when a crash is detected.
