Design of Experiments Guide > Screening Designs > Build a Screening Design
Publication date: 06/21/2023
Build a screening design by selecting DOE > Classical >Two Level Screening > Screening Design.
Note: The two level screening design option is not limited to only two level factors.
The screening design updates as you work through the design steps.
Responses
Factors
Choose Screening Type
Choose from a List of Fractional Factorial Designs
Design Type
Resolution in Screening Designs
Display and Modify Design
Main Effects Screening Designs
Design Generation
Design
Design Evaluation
Output Options
Make Table
