Publication date: 06/21/2023
Choose Screening Type
In the Screening Design platform, the Choose Screening Type section enables you to select a standard design or to construct a main effects design.
If a standard design can accommodate your factors and levels, two options appear in the Choose Screening Type panel. See Choose Screening Type Options.
If no listed standard design exists for your factors and levels, then the Choose Screening Type panel does not appear. The Design Generation section for constructing a main effects screening design opens. See Design Generation.
Choose from a list of fractional factorial designs
Enables you to select from a list of designs. This option is the default. See Choose from a List of Fractional Factorial Designs.
Construct a main effects screening design
Opens the Design Generation section where you can specify the number of runs in the main effects screening design. For more information about main effects screening designs, see Main Effects Screening Designs.
