The Predictor Screening red triangle menu has the following options:
Save Results
Creates a new data table that contains the predictor ranking table from the report.
See Local Data Filters in JMP Reports, Redo Menus in JMP Reports, Group Platform, and Save Script Menus in JMP Reports in Using JMP for more information about the following options:
Local Data Filter
Redo
Platform Preferences
Save Script
Save By-Group Script
