DRAFT help
Publication date: 09/20/2024
Manage Limits
Manage Limits for Many Columns
The Manage Limits platform enables you to quickly add or edit many limits or column property metadata for several columns at once. The limits and metadata are then used in future analyses. You can also specify importance values for each process and indicate whether limits should appear in graphs as reference lines.
The following types of limits and metadata can be specified in Manage Limits:
Specification limits
Importance values
Process Screening metadata, such as centerline, control chart sigma, and measurement sigma
Measurement Systems Analysis metadata, such as tolerance range, lower tolerance, upper tolerance
Measurement Systems Analysis metadata specific to Type 1 Gauge analysis, such as reference and resolution
Detection limits
Contents
Example of Manage Limits
Launch the Manage Limits Platform
The Manage Limits Report
Process Capability
Process Screening
MSA
Detection Limits
Buttons
Manage Limits Options
