Scripting Guide > Display Trees > Modal Windows in JSL > Constructors for Column Dialogs
发布日期: 09/18/2023
You can use constructors such as Edit Number() and Check Box() in column dialogs, which construct launch windows with a column selector. The following example shows a typical column dialog with an Edit Number() box:
Column Dialog(
	ex x = ColList( "X", Max Col( 1 ) ),
	HList( "Alpha",
	ex = Edit Number( .05 ) )
表 11.3 describes the column dialog constructors.
Notes:
A column dialog automatically includes the list of columns in the data table.
A column dialog also automatically includes OK, Cancel, and Remove buttons.
Table 11.3 Column Dialog Constructors
Constructor
Syntax
Explanation
Button
Button( "OK" ), Button( "Cancel" )
Draws an OK or a Cancel button. If OK is clicked, Button(1) is returned. If Cancel is clicked, Button(–1) is returned.
Check Box
var( CheckBox( "Text after box", <1|0> ) )
When OK is clicked, a selected check box assigns 1 to the variable. A check box that is not selected assigns 0 to the variable.
Add an optional 1 for the check box to be selected (on), or 0 for it to be not selected (off) when the window first appears. The default value is 0 (off).
Col List
var=Col List( "role", <MaxCol( n )>, <Datatype( type )> )
Creates a selection destination with a role button; the user’s choices are returned in a list item of the form var={choice 1, choice 2, …, choice n}.
You can specify the minimum and maximum number of columns using MinCol( n ) or MaxCol( n ).
You can specify the required data type of the column using Datatype(type). The choices for type are Numeric, Character, or Rowstate.
Combo Box
var( ComboBox( "choice1", "choice2", ...) )
Produces a menu with the choices listed. The first choice is the default. Choices evaluate to quoted text strings. Choices can also be inside a list.
Edit Number
var( Edit Number( number ) )
Produces an edit field for a number with number as the default value. When OK is clicked, the number entered in the field is assigned to the variable.
Edit Text
var( Edit Text( "string", <width(x)> ) )
Produces an edit field for a string with string as the default value. You can also specify the minimum width of the box in pixels. The default width is 72 pixels. When OK is clicked, the text entered in the field is assigned to the variable.
HList
HList( item, item, ... )
Top aligns and spaces the items in a horizontal row. Placing a pair of VLists within an HList produces a top aligned, spaced pair of columns.
Line Up Box
Line Up Box( n, item_11, item_12, ..., item_1n, ..., item_nn )
Lines up the items listed in n columns, where item_ij is the jth item of the ith row.
List Box
var=List Box(
{"item", "item",
width( 50 ),
max selected( 2 ),
NLines( 6 )
Creates a display box that contains a list of items.
Radio Buttons
var( RadioButtons( "choice1", "choice2", ... ) )
Produces a vertical, left-justified list of radio buttons with the choices specified. The first choice is the default. When OK is clicked, the button that is selected is assigned to the variable. Choices must evaluate to quoted text strings.
string
"string"
Draws text in the window. For example, can include a labeling string before an Edit Number field. All strings must be quoted.
VList
VList( item, item, ... )
Left aligns and spaces the items in a vertical column. Placing a pair of HLists within a VList produces a left-aligned, spaced pair of rows.
