JMP 14.2 联机文档
发现 JMP
使用 JMP
基本分析
基本绘图
刻画器指南
实验设计指南
拟合线性模型
预测和专业建模
多元方法
质量和过程方法
可靠性和生存方法
消费者研究
Scripting Guide
JSL Syntax Reference
该帮助的版本不再更新,请参见
获取最新的版本.
Scripting Guide
Scripting Platforms
Specify Which Columns to Analyze
• Specify Multiple Column Names at Once
上一个
下一个
If you have a lot of column names, instead of listing each one individually, you can use lists as column arguments. The following example gets the column names from a list and runs a Distribution on each column in the list.
dt =
Open
"$SAMPLE_DATA/Cities.jmp"
dt <<
Fit Group
Oneway
( Y( {:SO2, :POP} ), X( :State ) ) );
If you do not know the column names when you are writing the script, use column indices, as done in the following example.
dt =
Open
"$SAMPLE_DATA/Big Class.jmp"
dt <<
Distribution
( Y(
1
N Col
( dt ) ) );
You can also use indices when specifying effects as shown here:
dt << Fit Model( Y( :y ), Effects( 1 :: 4 ) );
