JMP 14.2 联机文档
发现 JMP
使用 JMP
基本分析
基本绘图
刻画器指南
实验设计指南
拟合线性模型
预测和专业建模
多元方法
质量和过程方法
可靠性和生存方法
消费者研究
Scripting Guide
JSL Syntax Reference
该帮助的版本不再更新,请参见
获取最新的版本.
Scripting Guide
Scripting Platforms
Specify Which Columns to Analyze
• Enable Users to Specify Columns
上一个
下一个
Instead of specifying analysis columns yourself, you can enable a user to specify them, but you can still control what happens after they do so. In this case, use an empty specification. The following example runs the Distribution launch window:
Distribution();
In this scenario, the Distribution launch window appears and the user can choose the columns to analyze. After the user selects the columns and clicks
OK
, the Distribution report is shown as specified.
