提示:For a complete list of DOE scripting options, select Help > Scripting Index, select Objects from the menu, and search for DOE.
Defines a vector that is added to the diagonal elements of the X'X matrix. This new matrix is used in finding the D-optimal design. The following example adds the elements of vector to the diagonal elements of the XX matrix:
